94 Firehawk code issue
Old Jun 10, 2016 | 07:09 AM
terrygar's Avatar
Default 94 Firehawk code issue
Hello I have a great running 94 Firehawk and as I was driving the ABS INOP idiot light came on, has anyone had experience with this, is the ABS module a problem to find and install? Can runs fine and has brakes, help if you can.
Thanks
Terry
Old Jun 10, 2016 | 08:28 AM
shbox's Avatar
You can scan for trouble ABS trouble codes with a program called Scan9495. Might just be a wheel sensor.
Old Jun 12, 2016 | 09:53 PM
jclark3's Avatar
Could be wheel sensor, broken wire by wheel sensor, or hub bearing starting to go. Mine was the hub bearing
