new idea about porting heads ! lets discuss
All I see is a massive air flow loss with a set up like this on an LT1. Sure the ports will be huge, but velocity will be almost non-existent even with perfectly tuned scavenging and ram tuning.
If you want to make some good power using the Gen II LT1, then call up and choose one of the following companies to work over a set of heads for you.
http://elliottsportworks.com/
http://www.advancedinduction.com/
You actually don't need heads at all. Heads were just put on engines after the damn democrats wanted to crack down on emissions. Take off the heads all together and run it, gives unlimited air to the Pistons and you make real power.
