Lloyd cam with 1.6 rockers
Decided to ditch my cc305 cam for a LE 216/224, .568/.565 112 LSA cam since im looking for maximum torq/hp below 5500rpm.
Will this amount of lift work with my gm 1.6 roller rockers? I read that these rockers are only good to .575 lift.
Im assuming my pac 1218 springs will be adequate?
Generally the cam lift specs are based on a 1:5 ratio rocker...with the 1:6 it would appear the LE cam exceeds the max lift of the GM RR
Certainly confirm with Lloyd the cam specs are for 1:5 lift and then do the math for 1:6...which would be above the .575 max lift of the GM RR
well if true than the lift is "just" under what OP says max lift is for the GM 1:6 RR. but at .007 under max lift I think that is to tight
Again, ask Lloyd if those RR should be used
You may have Comp Ultra's in your future...
