Lt1 heads and cam
Old Jul 28, 2016 | 10:33 PM
KW Baraka's Avatar
Originally Posted by ******
....ah lloyd can install the studs & guide plates....but op will need to install the rr.......
Yes.....wasn't thinking that through !
KW
Old Jul 28, 2016 | 10:45 PM
adurell's Avatar
Originally Posted by KW Baraka
Swap the heads/intake (and the fuel rails) on the cars so that the '96 has the LE hardware.
Get a new cam and appropriate valve springs from LE for the '96.
And then.....if you're not too attached to the '93.....sell it.....for a reasonable price.
It's what I'd do, anyway.
KW
Yeah I was kinda thinking that or would it be easier to swap the whole engines or is there a gain to the 96 engine? The 96 is a way nicer car by far just cause it's leather, t top, 6 spd manual. But the 93 I picked up is also in great shape.
Old Jul 29, 2016 | 09:36 AM
BadAzz96Z28's Avatar
The 93-94 came with a different style Opti-spark than the 95-97 did. They are not interchangeable from how they are mechanically driven off the cam. You should still be able to drop in the complete 93 engine with the Opti that's on it, just keep that in mind if you ever have to buy a replacement down the road.
When I cammed my 94Z, I changed the Opti to the 95+ vented unit so the cam was ordered to reflect that change.
If you end up swapping the complete '93 engine into the '96, make sure you don't forget to put a pilot bearing in the back of the crankshaft if your '93 is an Auto!
Old Jul 29, 2016 | 11:42 AM
adurell's Avatar
Awesome thanks for the information
