P0300 after header install
20-22psi with the key on and engine off
34psi engine on at idle with FPR vacuum hooked up
43psi engine on without FPR vacuum hooked up
The car has been hard to cold start for a while now. I'm guessing the low priming pressure doesn't help. What could cause this and would that be enough to throw the P0300 code? BTW I replaced the opti and wires with new AC Delco replacements a few months ago.
Edit: #5 plug looked fine, good color and not wet. #5 wire looked fine, no arching or burn marks. The O2 sensor (bank 1, sensor 1) voltage drops every time the misfire occurs.
The o2 drop voltage is normal during the misfire as you are getting a rich spike which will cause the voltage to go lower.
