Head Work?? or just valve seals?
with that said if they were still on the car you would be fine with not doing that and just doing locators, valve seals, springs, retainers & locks
if you had no oil consumption before and = compression on all cyl than the valve guides and seats are good.
Your initial post said you are replacing "seats"...I assume you mean what the valve spring sits on aka "locator" and not installing new valve "seats". If the later than you need a valve job to cut angle the valve seat to match the valve
IDK what compression you get with stock heads but I would think 11.xxx. Maybe someone who knows the "math" can reply regarding the .026 thick gasket with stock heads and what compression you get. IIRC the stock AL gasket is .049 thick on AL heads
I agree with the post saying if you are getting the heads "ported" later than get the valve job done then.
If I were not touching the heads regarding valve job or milling, I would just get the Victor gasket and put them back on
of course sending your heads to Lloyd Elliott would be ideal.
I have pac 1218 springs
CC 795 retainers, 611 locks, and 4705 spring seats "locators". Should drop right in and work great with my gm lt4 1.6 roller rockers i hope.
