Setting up Heads
your seat and open spring pressure will be slightly more than spec but again no big deal with the over all combo.
If you want to know for sure you can use a spring height tool to measure what your springs are really at since the heads are off the car. Easier to work on.
On the ARP stud install, use "thread sealer" (generally the white stuff), not loc-tite. 50 Ft Lbs TQ
You need a valve spring micrometer to really know. You can get a Proform tool on eBay for around $40-50.
And if your heads are unported then there's no need for thread sealer on rocker studs. All holes should be blind.
And yeah, I like permatex #2. I use it on head and water pump bolts all the time.
