Slow Crank - Video
You are turning the motor as we can see. Why isn't it starting? Usually all you need is for the motor to spin, get to a couple power strokes, & it should fire up. Have you checked the plugs? Are they firing? When was the last time you changed the opti? Maybe it went & it's firing at the wrong spot? Hope you get it figured man. Stay posted.
I think I have some clips for my voltmeter, if I can find them I will measure the starter wile I crank it. The opti is not even a year old and probably only has 1000 miles on it. I just put in new plugs and gapped them while I had the motor out for a cam swap. I haven't checked them because my understanding is that even without spark or fuel the motor should still turnover continuously and not stop and start like mine.
Don't even think of worrying about the opti until you figure out what is causing this slow crank problem.
What really puzzles me is why people go and make performance modifications on a car that was not running right from the start. Fix the current issues with the car, THEN start making mods when you know the thing is working okay. Otherwise, you end up with headaches like this....
I don't think putting a voltmeter on the starter is going to tell you anything(well, I shouldn't say that...it can tell you some things if you know what to look for...)....but if the problem is high resistance of the solenoid contacts you might be able to see a high voltage drop between the starter motor post and positive post on the solenoid. I'm assuming that the cables are good as you just replaced them.
Otherwise, you need a DC amp clamp to find out how much current is being pulled and what circuit is pulling the most load.
Edit: I just went out to my Z28, disabled the PCM, put my Fluke 85 on it and watched the battery voltage as I cranked it. There is an initial current spike that quickly drops the voltage to 9V, but then the voltage rises back to around 10.5 volts(as the engine gets spinning) and stays there during constant cranking.
So 10.5 volts is the goal you are looking for during constant cranking. This value could vary a little depending on the current delivery capacity of the battery.
As an FYI, battery voltage alone is not the end all and be all of battery health.
The battery can't meet the load demand being put on it. This formula can show you why.... and this is simplifying things some but I think it will show why the voltage drops.
Watts = Voltage x Current
Say you have a battery that is rated for 500A @12V.
Via the formula above, that shakes out to 6000 watts.
Say you put a load on the battery that pulls 600 amps....instead of 500 amps. The power that the battery can deliver is 6000 watts. That can't change, but if your load is trying to pull 600A the number that changes will be the voltage.
6000/600 = 10V.
So... in general, that is why voltage falls when you try to pull more than the rated current capacity of a power supply.
There are other factors to consider and I have over simplified the above, but the bottom line is there is simply too much load on the battery(bad starter, very high compression engine, something else other than engine load causing issues....there is transmission load to consider too) or there is a problem with the battery.
I would start troubleshooting this by putting a DC amp clamp on the positive cable running to the starter to see how much current it is pulling when starting. I'll try to get a reading off mine as a baseline in a day or so.
Something else to consider is to make sure that the grounds to the chassis and engine are in good shape. High resistance there could really cause problems during high current situations.
Have a look at this...for what a ground issue can do...from ScannerDanner's excellent youtube channel.
I had been regularly scanning for codes and none showed up until last night when i recorded the video. It was a P0100 code for MAF which make sense because it is unplugged right now.
I am almost positive that it is plugged in, I remember doing it, but I will double check tonight.
moehorsepower@peoplepc.com
One of the best tuners out there and cheaper than almost all of them, to boot.
I 100% agree with you on that! It pisses me off that I have already done all the hard work of pulling the motor, doing the whole swap, and putting it back in only to have to tinker with electrical sh*t. I guess its a good learning experience though.
