Going to be droping my rearend for the first time any tips
So this is how it came to be I was just going to change wheel bearings being as they were making some noise and was going to call it good and wait for the rear end to blow up then get a 9inch but it had other plans I get the old bearing out and whent to put the new one in gave it a few wacks and the thing falls apart I try to pull it out but it won't come back out I have the proper tools and got the old one out just fine but this new broken pos is stuck in there so I've decide if it wants to be difficult I'll just pull it out and get me a 9inch now so being as this is my first time doing this any tips or tricks to this and I don't have a lift so I'll be doing this on the ground with Jack stands thanks
Start with the suspension loaded. I used 2 wheel chocks for the front, 2 jack stands for the rear of the body and two jack stands for the rear end. If I remember right I did the panhard bar first, torque arm second, sway bar third, rear shocks fourth, disconnected brake lines fifth, lowered rear off stands then remove control arms last.
Installing the 9" is a ***** and you will absolutely need a second person, possibly a third to tag in when one of you are tired of cursing it out. I was able to do my 12 bolt by myself.
EDIT: I should probably clarify that the 9" has a wavetrac and the 12 bolt has a spool. The weight difference wasn't as big of a deal as the size of the damned thing.
Village Troll
Exactly. Remove everything off the diff., then lower with control arms still connected and disconnect them from the diff. last. Then do exact opposite when re-installing. This way it keeps the diff. from rocking and falling off the jack when lowering and raising.
