CC503 stall reccomendations?
Old Sep 13, 2016 | 09:17 PM
elis94camaro's Avatar
Default CC503 stall reccomendations?
I have a cc503 cam in a 355 with 3:42 rear end gears and I was wondering what stall size and brand you all would reccomend me. I will never go to the track with this car, I just daily drive it and like to do the occasional stoplight pull with it. I want something budget friendly and something that will be dependable.
Old Sep 14, 2016 | 03:12 AM
lt1-xjs's Avatar
Yank SS3600.
Old Sep 14, 2016 | 07:27 AM
bowtienut's Avatar
"will never go to the track"....."budget friendly" ......
I'd go with a Street Edge 3000 stall (9.5").
Old Sep 14, 2016 | 08:29 AM
StealthFormula's Avatar
I vote Yank SS3200 since it's a daily driver that won't see track time. I use to run the SS3600 and the cc503 cam and it was awesome but I think the 3200 would be more appropriate in your case. Yanks aren't budget friendly but they are well worth what they cost. I would maybe look for a used one if a new one is out of your budget.
Old Sep 14, 2016 | 08:31 AM
bowtienut's Avatar
Yep, SS3200 would be ideal if it's within your budget. It will drive just slightly tighter than the Edge 3000 I mentioned.
Old Sep 14, 2016 | 09:28 AM
Will the yank ss converter feel stock under normal driving conditions? Is a transmission cooler necessary
or can I add one later? I am on a budget but I want to know if this would be the best converter for me even though I won't see the track?
Old Sep 14, 2016 | 10:10 AM
A trans cooler is a must no matter what converter you choose. I found this out the hard way. I've been running the B&M 70264 cooler for many many years and it's under $100.
My best friend has a Yank SS3200 in his car. You hardly know the converter is there until you begin to lay into it which is ideal for a DD in my opinion. It's a very tight converter, whatever converter you end up choosing just make sure it's pretty tight.
Old Sep 14, 2016 | 10:32 PM
Would a revmax 3500 stall be to much? Reason I ask is because I can get a used one for
cheap.
Old Sep 15, 2016 | 05:51 AM
bowtienut's Avatar
cheap.
Too much in my opinion.
I don't know about their quality, but I'll bet money it'll feel looser than the Yank SS3600 that was first suggested. I wouldn't want it in a daily driver.
Old Sep 15, 2016 | 08:19 AM
I agree.
IMO, do it once and do it right. If you go the cheap route and end up disliking the converter it's going to cost you more money and time in the end.
Old Feb 4, 2019 | 01:51 AM
Johnny Barron's Avatar
Default What do i need for a 503 cam?
i just wanted to ask what i would need for a 503 cam . i have 1.6 rockers and ls7 lifters. i have stock headers . with stock lifters. What else what i need. Im nust a stock lt1. Trying to go bigger. What do yall recommend ??
Old Feb 6, 2019 | 11:25 PM
KW Baraka's Avatar
Originally Posted by Johnny Barron
i just wanted to ask...….What do yall recommend ??
That you start your own thread......since you asked.
KW
