Loss of trap speed
Old Oct 8, 2016 | 07:49 PM
ElkySS's Avatar
Default Loss of trap speed
Went to the drag strip last night and noticed a huge loss in trap speed. The car previously went 122 but the best I could get out of it this time was 113.
I changed from a cai and 1le elbow to a ws6 intake and hood setup an from 1-3/4 headers to stepped 1-7/8 headers and 3in true duals, and from a 26in radial to a 28in bias tire.
The motor still runs smooth. Anyone got any ideas?
Old Oct 8, 2016 | 07:58 PM
NewOrleansLT1's Avatar
Might need a tune.. Maybe the change in tire size causing the trans to short ****.. Just a guess..
Old Oct 8, 2016 | 08:13 PM
SS RRR's Avatar
Village Troll
That's a **** ton of lost power. I'd first look into a dead cylinder.
Old Oct 8, 2016 | 08:22 PM
ACE1252's Avatar
Valve float on the top end maybe? To drop ~10mph is pretty big.
How did the times compare?
Can you throw the 26" tire back on it and see how it runs?
Old Oct 8, 2016 | 08:52 PM
ElkySS's Avatar
It's an M6
The motor still runs very smooth for having a .582 cam.
Top end was still very smooth
I don't have the radials anymore.
Old Oct 9, 2016 | 09:45 AM
Nader454's Avatar
Was there a big difference in weather conditions? Clutch slipping?
Old Oct 9, 2016 | 10:49 AM
SS RRR's Avatar
Village Troll
I failed to see that you went up to a 28 inch tire. As stated from someone else in the other thread that may be your problem. Changing the final drive ratio can make a hell of a difference.
Old Oct 9, 2016 | 12:56 PM
ACE1252's Avatar
Can you post up the timeslips from the two runs?
Old Oct 9, 2016 | 06:10 PM
ElkySS's Avatar
The timeslip showing 122 is long gone. But it has a 1.6 60ft, 11.56, 122.
The latest one was 1.7 60ft, 12.1, 113.
Weather conditions weren't too different. If anything, the older timeslip was taken in worse conditions.
The clutch is freshly broken in. No slipping.
I knew I'd loose a few MPH going up in tire size but this seems a bit extreme. I'm running 4.10 gears btw
Old Oct 9, 2016 | 06:36 PM
Well dude I was in your same shoes when I had a dead cylinder from a cracked spark plug after changing out headers.. I lost 9mph and a full sec. in et.. Fixed the problem and all was well.. I found the problem by poking a hole in the top of a water bottle and skeeting water on each primary and bingo...
Old Oct 9, 2016 | 06:53 PM
ElkySS's Avatar
I did just replace all the spark plugs. I'll give that a shot when I get a chance.
Old Oct 10, 2016 | 06:44 AM
ElkySS's Avatar
Just went out and sprayed water all over my headers and plug wires. Didn't see any arching anywhere.
Old Oct 10, 2016 | 09:46 AM
FIVEPOINT7's Avatar
I don't think he was looking for arcing when he was spraying water, a dead cylinder would cause that primary to not be hot, so the water wont flash boil on that primary like it would on a good cylinder. Pull plugs and inspect?
Old Oct 10, 2016 | 09:59 AM
Exactly ^^^^^
Old Oct 10, 2016 | 01:12 PM
FIVEPOINT7's Avatar
Exactly ^^^^^
That's actually a pretty cool trick, I'm gonna save that in my idea box if I ever need it.
Old Oct 10, 2016 | 01:36 PM
transbird95's Avatar
Temp guns work really nice too if you dont want to use water.
Old Oct 10, 2016 | 06:03 PM
ElkySS's Avatar
Ah, I misunderstood. I'll check that with a temp gun tomorrow.
Old Oct 11, 2016 | 02:12 PM
ElkySS's Avatar
Checked each runner after a 30 min drive. All were roughly 300 degrees
Old Oct 11, 2016 | 02:20 PM
Atomic's Avatar
I need a gauge for that
You need to do it from a cold start. I just use my finger to test the primaries, but obviously this only works on a cold start when its not scorching.
Old Oct 11, 2016 | 02:51 PM
kinglt-1's Avatar
My guess would be a dead cylinder as well or maybe it idlles on all 8 but dropping one under wot.
