LT1 wont idle
I am running open headers until I can drive to the exhaust shop. Did the break in with the O2's plugged in, messaged Solomon about my idle issue and he said to unplug the O2's and reset pcm. Did that today and took a video on second start up.
Am I missing anything? Using Pacesetter mids with egr hook ups and the egr pipe might not be sealed 100% but i planned on blocking it off fully after I smogged. Car threw 2 codes today on first start up before dying. P0336 crank sensor(Which ive read the opti detects the cam and timing and this sensor only helps detect misfires and cant be the reason?) and P0500 vehicle speed sensor. Wrote codes down and then cleared using scanner. Thanks guys
You may need to data log it and post up the log so we can look at what it's doing.
adjusting the TB screw (read don't do it) will change the TPS volts. More a problem with A4 vs T56 cars
what are your IAC readings at idle??
http://www.golenengineservice.com/do.../Adj%20TPS.pdf
Can you recomend a good scanner to use that will show IAC. Reason I didnt get one is cause i heard most scanners wont read IAC on an lt1.
Does the video sound like something is wrong mechanically? Its getting harder for me to really diagnose this since I dont have too much experience
yeah I am familiar with the Golen TB thing. That is for larger, aftermarket, TB's. I personally don't subscribe to that method. I did the TB "drill" mod but had the car hooked up to my Auto Tap when doing that. Your TB is stock but for H/C builds it may need the small IAC hole between blades opened 1/64th"...but DO NOT drill anything until you are hooked up to something that can read IAC counts. They want to be 32 at idle (30-35) with engine at operating temp and in closed loop
The fact you don't have your 02's hooked up yet keeps the PCM in open loop mode so not ideal to be tweaking TB while it is still in open loop
nothing I can hear in video from this side of the keyboard that is a problem other than it shuts off quick in 1st video.
Edit: seems maybe the wiring is bad? used the multimeter on the grey and black outlets and they measured only .18 and .01. Seems low. Got the car to idle again and not die, put it in gear and tried to go and it died on me and threw a p0200, checked injector plugs to make sure right one and found one that popped right off. Battery's dead again tho so gonna charge it and try again later
