New 409SS 3" single exhaust
Old Nov 18, 2016 | 12:50 PM
smitty2919's Avatar
Default New 409SS 3" single exhaust
Not much traffic in the LS section on this but figured I would also share with the LT section since my car is a 95.
Car originally came with PS catless Y pipe and Borla adj catback. It has since gone through a modified Borla catback, then tried to "fix" the merge in the PS midpipe.
First midpipe change in an attempt to smooth the merge. You can see the original merge here:
Tried to cut off as much as I could and stuff on a 4" dia Flowmaster "race" muffler followed by a 3" glasspack:
Placed an order for some pipe and 3" Vband:
Couple days later planning this out I came up with this. My friend had a good idea for a better Y merge design.
I took the old exhaust off last Thursday and had a fully mocked up/tacked system last night ready for welding. All work was done with the car on jackstands and nothing more than a 4" electric cutoff wheel and a tape measure. The dark areas are where I needed to heat the pipe to dent it for clearance. The DS dent is for the typical LT1 floorboard area. the other area is for the TA clearance.
I have a Watts Link and can confirm that the V-Band rings can be removed between the floor and Watts link. the goal is to have the rear section removable to run a full size muffler for winter to be quiet then swap out for a more aggressive system for summer.
Exhaust is currently welded and I plan to get it on the car and running by tomorrow.
Update: Videos of both setups
Old Nov 18, 2016 | 09:37 PM
n2oblkz's Avatar
That looks great and I bet it'll sound great too. Be sure to post a video clip of it when you get it on.
Old Nov 23, 2016 | 07:55 AM
smitty2919's Avatar
This system turned out great. My old system had some popping going on low rpm high load with a glasspack style muffler. With the new system and the same muffler, the popping is cut down DRASTICALLY. It has a hint of LS motor tone now.
This is the popping I was trying to get rid of at the 0:24 mark and 0:57 mark.
The new merge REALLY smoothed that out. I will never build a conventional merge again.
I will work to get a video this weekend.
Old Nov 23, 2016 | 08:57 AM
n2oblkz's Avatar
Sounds great!
Old Nov 23, 2016 | 10:27 AM
smitty2919's Avatar
Originally Posted by n2oblkz
Sounds great!
That video was the "old" modified PS Y-pipe...IMO the new system is smoother/better.
During the process...Old vs New:
Installed:
Tip will be remade to mimic the MUFFLEX style hidden tip.
Old Nov 23, 2016 | 11:11 AM
n2oblkz's Avatar
I'm curious to hear the new setup
Old Nov 26, 2016 | 01:46 PM
smitty2919's Avatar
Added video to OP
Old Nov 26, 2016 | 02:23 PM
n2oblkz's Avatar
Sounds great
