whats next??
Old Dec 13, 2016 | 05:21 PM
SS RRR's Avatar
Village Troll
I'd think peak would be farther along than 7k? If so, maybe it's a good idea to look into shaft mounts?
Old Dec 13, 2016 | 09:20 PM
Nostang's Avatar
My combo peaked at 6600 rpms on the engine dyno with the same cam on a 108lsa and a single plane. The HP was almost the same (within 20hp) from 6200-7300 before it started to drop off after 7400. It will def pull to 7400-7500 no problem. I agree on the shaft mount for high rpms.
Old Dec 14, 2016 | 08:41 PM
Jon114's Avatar
ok. So i have everything but the shaft mounts. ill probably put it in this winter since i can never leave anything alone. Haha
Old Dec 14, 2016 | 09:06 PM
Nostang's Avatar
Not sure if you have a small base circle cam or not but check your rod bolt to cam clearance if you are able. Also, make sure to check your ptv clearance when installing this cam. I had to flycut my pistons when the machine shop checked my ptv as it was really close.
Old Dec 15, 2016 | 06:54 PM
Jon114's Avatar
ok man thanks alot! yea when i get around to doing it ill get everything checked out for sure.
