383 GM Performance LT1/LT4 NEW
Old Dec 14, 2016 | 10:56 AM
94-LT1 ELLE VA's Avatar
Default 383 GM Performance LT1/LT4 NEW
New never installed 383 shortblock.. .040 over with mahle flat top pistons, forged gm crank, forged scat connecting rods, and the short block came with a .490 lift cam that will come with it as well. $2250 for short block. also have a factory lt1 intake with fuel rails, a pretty much new msd optispark for a cam dowel pin set up came off my 1994 z28, 58mm edelbrock throttle body, lt1 procharger mounting bracket for a p1/d1/f1. message me if youre interested in any of the item.. I may have more stuff than that too. just ask.
LOCATED IN SIOUX FALLS SD
605-360-6360
Attached Thumbnails 383 GM Performance LT1/LT4 NEW-20161213_173829-1-.jpg   383 GM Performance LT1/LT4 NEW-20161213_173759-1-.jpg   383 GM Performance LT1/LT4 NEW-20161213_173838-1-.jpg
Old Dec 16, 2016 | 12:12 PM
KW Baraka's Avatar
Originally Posted by 94-LT1 ELLE VA
.......and the short block came with a .490 lift cam that will come with it as well......
OK; stating "a .490 lift cam" tells us almost nothing what-so-ever about the cam's performance parameters.
Can you provide more information? Duration? LSA? Valve opening/closing events?
Also, what would be the compression ratio with a stock sized combustion chamber?
Thanks!
KW
Old Dec 16, 2016 | 03:07 PM
SS RRR's Avatar
Village Troll
Maybe it's just the shadow, but this one piston looks like there's at least .050 clearance between it and the cylinder wall...
Attached Thumbnails 383 GM Performance LT1/LT4 NEW-2016-12-16_140330.png
