EVAP & air pump question
Old Jan 2, 2017 | 12:15 PM
350 groundpounder's Avatar
Default EVAP & air pump question
Can anyone tell me where the tube on the bottom of the evap goes that is currently open to air in the pic? Its on a 96z28. Also the other pic is a air module hooked on by a bracket by the coil. Is this used for anything besides the air pump? I would like to get rid of it! I deleted the air pump and had it tuned out.
Attached Thumbnails EVAP & air pump question-20170102_124932.jpg   EVAP & air pump question-20170102_125021.jpg
Old Jan 2, 2017 | 12:22 PM
atlantadan's Avatar
Vents to the atmosphere. Nothing is connected there. Can't help with the second pic
Old Jan 2, 2017 | 12:48 PM
Thanks, i thought it was supp to vent into a canister in the fender. Ohh thats right the canister is in the rear fender. I notice my gas tank used to have lots of pressure build up when i opened the gas cap?
Old Jan 2, 2017 | 01:13 PM
Spartan7's Avatar
That's the vacuum purge switch, you're thinking of the EVAP purge solenoid. The switch purges excess vacuum in the purge line, and yes that hose is supposed to be open to atmosphere.
The second is only for the AIR pump. If you're removing it, that air solenoid can go along with it. Just remember to cap off the intake where the hose went.
Old Jan 2, 2017 | 03:47 PM
Alright thanks. Just got to go find a nipple block off for the intake then.
Old Jan 2, 2017 | 05:22 PM
BALLSS's Avatar
they are available at auto part stores in packs of various sizes.
Old Jan 2, 2017 | 05:28 PM
Picked up some 3/16 nipple covers! Gotta get headers on, otvc kit on then its time to fire up this little cammed lt1.
