Valve covers
Old Jan 26, 2017 | 12:23 AM
WKD Z's Avatar
Default Valve covers
Will be doing alternator relocation and looking into aftermarket valve covers. Which covers are you guys using that will clearance the 1.6 rockers? I had to trim my factory ones to clear.
Old Jan 26, 2017 | 08:03 AM
aroberson77's Avatar
Cantons or any other fabricated ones will. I have also seen on ebay that there are stock style tall covers as well. Any centerbolt chevy valve cover will fit your heads
Old Jan 26, 2017 | 12:37 PM
StealthFormula's Avatar
Another option would be the LT4 composite valve covers. They will clearance 1.6 RR's without any grinding. They are about $200 for a good used set so a bit pricey but they've been my favorite set of valve covers so far.
Old Jan 26, 2017 | 02:12 PM
The LT4 covers look awesome, does someone make a replica thats cheaper
Old Jan 26, 2017 | 02:46 PM
Not that I am aware of.
Old Jan 26, 2017 | 03:21 PM
Too bad
Old Jan 28, 2017 | 07:09 AM
leadfoot4's Avatar
I would avoid the Proform tall covers. I had a pair, at one time, and they weren't strong enough to be snugged down, and not seep oil. After I installed them, I had to "snug them up" every day, literally, and after about a week, or so, the tops were starting to cave in.....
Old Jan 28, 2017 | 10:29 AM
Evaporate's Avatar
I have LT4 valve covers for sale, pm if you're interested.
Old Jan 28, 2017 | 10:46 AM
jasonz28camaro's Avatar
Don't get cantons. Hard the seal. Get the lt4 or find a set that has a lip to hold the gasket, cantons don't have the lip and it makes it difficult to seal. At least my cantons did not have the lip.
Old Jan 28, 2017 | 11:23 AM
Blackbirdws6's Avatar
Composite VCs are the best I've used. I love the o-ring style gasket, fastener setup, looks and size. Not cheap but worth the money IMO.
Old Jan 28, 2017 | 05:03 PM
CFLFORMULA93's Avatar
ill have to second that i have the canton vc as well no lip and they are a pita to get sealed. i found a cork gasket that seemed to work but having them off and on it didnt last long
Old Jan 28, 2017 | 10:20 PM
Dirty_Bird's Avatar
Had cantons, bought sbc extra thick cork ones, trimmed the perimeter bolt holes a bit and high tacked them to the covers. Didnt leak on me
Old Jan 29, 2017 | 08:35 PM
Cantons worked fine with a cork gasket but they are bigger than necessary. They look cool though.
Old Feb 8, 2017 | 01:04 PM
I may do a little project and use the stock bottom but add a taller top, we'll see though
Old Feb 9, 2017 | 12:13 AM
Puck's Avatar
No issues or leaks with my Cantons, even with the annoying rubber gaskets. First stuck the gaskets to the VC's with a small amount of silicone then let it tack before installing them together.
Would be a PITA to install a rubber gasket dry with them or by putting on the head first since it will move all over the place.
Old Feb 9, 2017 | 08:41 AM
that was the only issue with mine and the cork gasket was keeping everything lined up while trying to bolt up....i would imagine letting them tack up on the vc first would help
