1993 t.a.
Old Jan 30, 2017 | 05:51 PM
gmansvette's Avatar
Default 1993 t.a.
Hello Im Ricky and in process in changing my 2000 S10 extended cab narrow bed truck to a standard trans and a aluminum head lLt1this truck has the fuse block and most wiring under the hood not the dash. So has to have 2 elm's one for ylthe motor and the other for all the rest of junk like lights etc... I'm working on a stand alone harness. Have plenty info on the newt lt1's. But not the early ones. Anybody have a Pinout or know more about the harness ? Also who flashes cm for no emissions. No knock, o2's, no cats and all that jack. Can't afford a lot thanks Ricky
Old Jan 31, 2017 | 08:31 AM
lt1-xjs's Avatar
http://www.lt1swap.com/93lt1a4.htm
Old Jan 31, 2017 | 05:20 PM
gmansvette's Avatar
Default Pinout
I have this information from lt1swap but I need to know what each plug or pin goes to on the 4 plug ecm plugs. If you or anyone else has this information please let me know. Thanks for your help
Old Jan 31, 2017 | 05:33 PM
BALLSS's Avatar
this might help
courtesy of shbox
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
Old Jan 31, 2017 | 05:49 PM
lt1-xjs's Avatar
The link I posted is the 1993 wiring diagram, it tells you what the 4 connectors are and where they go.
Old Feb 1, 2017 | 05:20 PM
gmansvette's Avatar
Default I tried to go to tread but couldn't change to pre 94
I attempted to go to shbox and modify to 93 or 94 buthad no luck my pcm has 4 /21 wire plugs
Old Feb 2, 2017 | 03:55 PM
Flycaster1977's Avatar
[/http://www.thirdgen.org/forums/ltx-lsx/176800-lt1-wiring-dummies.html
might help
