Back to stock,rebuild 385 or LS
Idea #1
Car currently has a pull a part find 385 stroker. However it has not run right and does have an oil pressure problem. If you want a quick read go here.
https://ls1tech.com/forums/lt1-lt4-m...ard-today.html
Anyways that engine would need to be torn down. I have my cars original block that has been setup for an arp stud kit. So would need to bore it out from .030 over to .040 for the pistons that are in the current 385. I do not trust the 385 block so it would be going into the trash. Using my old block would allow a windage tray and it also did not have any oil pressure problems. This should solve the oil pressure problems.
So this would mean engine rebuild. Biggest problem is the tune. Car was an auto and the tune was garbage. Not just bad its horrible. Lets just say 5 gallons of gas was gone in 12 miles or less. So would need something to break in the car. Could get a pcm mail order tune and go from there. Granted I hate the cars current cam. Might go smaller. Could just be a call to lloyd elliot as its his current cam in the car.
Current cam specs --Lloyd Elliott LE2.2 cam @.050 236/236 W/1.6 Rockers .600/.600 Lobe Sep 107.
However in the years I have had the car. I have had zero luck with a cammed car. They drove awful even on a hotcam or cc503. Tunes were trash even being from pcm for less and the car actually felt slower than when it was in bolt on trim. Afr was off and they never ran long enough for me to get them to fix it. Mostly super lean while driving. Wide band used to peg out at over 18:1 while driving. WOT was ok but never felt right. That brings next idea up.
Idea #2
I now have access to a dealers license. A few lt1 cars are floating around copart and iaai. SC and TN require one for wrecks while GA and NC do not. One idea would be to buy a 100k good running car that has been wrecked. Few options out there including a couple t-56 cars. Auto would go cheaper but might be able to score a t-56 in budget. Would go see and hear it run in person. Make sure oil pressure is good. A few of the cars are rear hits. One I think would drive home even being an auto. Would probably tow home just to be safe but you get the idea.
Plan would be get a car home take the engine out. Part the rest. Give it 3-4 weeks cut it up and take it to scrap. T-56 car would help the cause as those prices have gone crazy in the last little bit. So could help the refund budget on the part out side of things. However I would want to hear the car run. Only downside are most are 95 cars. So would need to find an OBD2 timing cover that is not attached to my 385. Would probably run the ecu out of the wrecked car. But would like to keep it OBD2 if possible. Car is OBD1 right now so not to worried about it. Can always swap covers or find one. Not end of the world problem.
I like this idea. My car has really been down since 2009. Its been running on and off but never good enough to keep on the road. Put a stock engine back in and be happy. At least be able to drive the car again. Keep the 385 to the side and rebuild it for later on.
Idea #3
This one is from friends of mine who think I am crazy for holding out on lt1 stuff. They say buy a good wreck granted would need more than the $1500 as those still bring $2500+ at auction. Convert my t-56 to a ls1 style and swap everything over.
Not a bad idea but I see this getting expensive very quick. LS stuff is expensive and if that engine needs a rebuild parts get expensive really quick.
Not the biggest fan of this option but it has come on the list.
So there are a few ideas. If it was your build what would you do. I am between #1 and #2. Ls is kinda out unless I found a good LS car cheap. Not going truck engine as that takes everything from a ls1 car anyways.
As for the cars plan. Doubt it will ever be back at a drag strip ever again. Last time was 2009 when the car blew up. Have not even taken other cars. Its fun but 1/4 mile gets boring fast. 1/8 mile is fun but doubt I would go for more than a test and tune. I have thought about making it into an autocross car. Cam-C could be lots of fun. Car is close to weight and with a few other suspension mods the car could be pretty good.
So what would you guys do.
Still debating decisions.
Ive always been a fan of the lt1 and im putting one together now to swap into a third gen. Im trying to keep it somewhat civilized so i can just take the car out and have fun with it.
As for the F-body I always wanted a third gen. I ended up with a 4th gen as even back in 2008 finding a good third gen was hard, especially with a stick shift. The reason I ended up with a Firebird was I was driving my parents 96 Caprice. They said if you want a stick shift go buy one...so I did. Ended up going with a Lt1 car as the price was right. Granted I wanted a Green Z28 or SS Camaro with black interior. Ended up with a White Firebid Formula. At least it had the black interior and a stick shift.
If I was in your shoes, I'd find a good running LT1 to get the car on the road, I don't like projects to sit for long and if you can't enjoy them periodically it's easy to lose interest. A lot of times when I'm under my car busting my a** I'm asking myself why I bought this thing, but when I get it out on the road for a cruise, it makes it all feel worth it.
Then I'd get another LT1 motor and build it from the ground up your way. I have the original LT1 in my car now so I can enjoy it, and another LT1 on the stand that I'm building a 383 from. When that's all done and ready to go in, all I need to do is drop the subframe, swap the motor, put it all back together, and get a tune. That way there isn't much down time with the car off the road.
As for the parting out. I will buy a miata every once in a while and part it out. Heck when I was not working it helped pay the bills. Even getting one on the side makes a few extra bucks. So I have the space. My theory price kinda low and sell sell sell.
Could part this car. But I think I would rather have someone come buy it all for a good price. Then I don't have the emotional attachment of parting out my first car.
The reason behind buying a running wreck is that even years ago the good old Firebird let me down with a "good engine" decided to fail. Tear down showed a .030 rebuild that was horrible. Think that one made it 650 miles before its oil pressure dropped to 5psi at warm idle. That and the blow by was horrible. So if I am getting a used engine for this car. I want to hear it run in the old car before I install it into mine.
However a few buddies are saying try the 385. Split decisions.
1994 Camaro Z28 on the local pick and pull yard. Looks to have been a wreck in the front. Ok shape and had a new rad so looks like it has been somewhat cared for. Few things missing like the water pump and accessory bracket. Could be mine for $400 out the door with a 30 day warranty. I could run it as a non vented opti. I think my stock camshaft is around here somewhere. I could swap it over to a vented opti and use my new water pump and opti spark.Car had just under 114k miles. Oil smelled clean.
Link to its copart ad
https://www.copart.com/lot/41504026/
So this could be the donor I am looking for. Get the car running and driving and look into the 385 when I have time. Half the reason I am looking to get the car going again is the rust issue. Brother needed my spare alternator which turned out to be bad. Anyways I pulled the t-tops to find this.
Car has been sitting for 1.5 years. More since the last time the t-tops were off. I can see light water damage on the top of the windshield. Buddy says this is a bad glass install. Car was wrecked in 2002 when it hit a deer. Could have had one after that but who knows. It has not had one since April 2008. This needs to be taken care off asap. But kinda hard when the car sits out side. Need to get it to a garage and get the glass out to fix this. Could treat what I see now but without getting to the root of the problem nothing is going to change. So this is why I got in the mood to get the car running. As body work on a car that is not going to move is worthless. Even if it saves the roof line area.
Looking Pretty Sad
If you are trying to talk yourself out of doing anything with it, you probably should leave well enough alone and sell it. Worst thing that can happen is you be ***** deep into it and lose interest along with a pile of money.
