Piston damage?
Old Mar 9, 2017 | 08:49 AM
  #41
c0ncEpT's Avatar
Originally Posted by SS RRR
First I've heard of that. I always thought piston diameter was uniform from top to bottom.
This is why you usually don't see any signs of rubbing on the ring lands even tho a piston might rock over .030.
Old May 4, 2017 | 03:49 PM
  #42
z28jimmy's Avatar
Default Not a good update
Thought I would post an update to my situation.. Finally got the motor out of the car and brought it to Midwest Engine Tech who originally built it.. There was a lot more wrong than just one cracked piston.
#6 Lifter damaged
#1 - .012
#2 - .011
Crankshaft reluctor wheel damaged - .006 end play
Needs main/rod bearings
#3 Piston damaged
#6 Piston damaged
#7 Piston damaged
Rings worn
Timing set loose
#3 & #4 cylinders scuffed - Current bore is 4.030
Crank needs polish
Old May 5, 2017 | 11:13 AM
  #43
z28jimmy's Avatar
Has anyone ever seen this before? This is where the head gasket blew..
Old May 8, 2017 | 11:26 AM
  #44
z28jimmy's Avatar
Some pics of the pistons
Old May 8, 2017 | 01:20 PM
  #45
Shownomercy's Avatar
Man-Crush Warning
**** got hot.
Old Jun 1, 2017 | 01:49 PM
  #46
z28jimmy's Avatar
So now the question is what do I do? I have a good crank, rods, a block with splayed 4 bolt mains that needs to be honed.
Engine shop said it would cost 5 to 6k possible to get the whole thing back together.
Any suggestions? I am planning on using the car purely for going to shows/cruises and going to the drag strip a couple times a year. I wanted to go boosted route but with only one tuner in the area it kind of scares me.
Old Jun 1, 2017 | 03:47 PM
  #47
SS RRR's Avatar
Village Troll
If you want to go FI then go forged. If you are wanting to stay N/A then get another set of hyper-u's. What's going to be done on the rebuild for 5 or 6K?
Old Jun 2, 2017 | 09:58 AM
  #48
z28jimmy's Avatar
The good parts I have left are forged (crank & rods). For 5 to 6k it would be basically everything new.
Sonic test block
Pistons
Lifters
valve springs
bearings (All)
seals/gaskets
lifters timing set gears/chain
honing block and repairing the one cylinder head
assemble full motor
There was close to 2k in parts that I needed once I added them up.
I am really just looking for peoples thought on what they would do since I am saving up some money.
Old Jun 2, 2017 | 10:13 AM
  #49
BALLSS's Avatar
So $2k in parts....machining what, $1k??
So $2-$3k to assemble?
On the tall $ side for assembly....or is the shop R&R the motor from car also?
Old Jun 2, 2017 | 10:18 AM
  #50
z28jimmy's Avatar
Nope I removed and would be re-installing it.
Old Jun 2, 2017 | 10:20 AM
  #51
SS RRR's Avatar
Village Troll
What I would do is have the machine shop do the short block, repair the head and you do the rest.
Old Jun 2, 2017 | 10:25 AM
  #52
z28jimmy's Avatar
That's kind of what I was thinking.. I'll have to get a quote from him on how much it would be to do just the short block.
Old Jun 2, 2017 | 10:30 AM
  #53
SS RRR's Avatar
Village Troll
Yeah I'd be interested in knowing that as well.
