Steering Pump Issue please help 1996 Z28
Old Feb 21, 2017 | 05:37 PM
mxracer#143's Avatar
Default Steering Pump Issue please help 1996 Z28
I have my 1996 Z28 6 speed 85k miles car at a shop with a power steering pump issue. Pump was whining and making noise so I took it in.
The shop replaced the pump and that didn't cure the issue . Then we threw a rack and pionon at it.
Still no fix. And now/again replacement pumps making noise again. Replaced pump again and it whines also.
Shop recommends we go to a (GM) factory pump now . Called the dealer and says discontinued.
So now we don't know what to do.
2 pumps
1 rac
Lines replaced
Flushed
100 miles
Please lend a hand and thoughts. Need a place to purchase a good pump.
Thank You!
Old Feb 21, 2017 | 06:38 PM
ShovelMan's Avatar
ACDELCO 36P0252 - Can be had for $66.39 after core deposit refund.
Old Feb 21, 2017 | 11:06 PM
BALLSS's Avatar
all the PS pumps available are reman ones...
this shop does a very good rebuild and more. Very good feedback on these guys. Turn around can take some time
http://leepowersteering.com/
Old Feb 22, 2017 | 06:44 AM
smitty2919's Avatar
Talk to TurnOne
Old Feb 22, 2017 | 07:12 AM
aroberson77's Avatar
Turn one or find a used one on ebay, I got mine for 35 bucks and it doesn't whine at all.
Old Feb 22, 2017 | 09:21 AM
SS RRR's Avatar
Village Troll
Did these pumps start to whine immediately? If so, wondering if the system was bled properly after installs.
Old Feb 23, 2017 | 06:51 AM
SS RR can you tell me the bleeding procedure for This?
Not for sure if it was followed at installation.
Thank you!
Old Feb 23, 2017 | 08:15 AM
smitty2919's Avatar
If it makes you feel any better, I put in a NIB PSC pump and it still whines on my LT1. Has B&M cooler, -6AN high pressure line, all AN fittings and new return lines with new fluid.
I'll run it until something blows up. I've accepted the noise...
Old Feb 23, 2017 | 01:58 PM
Spartan7's Avatar
I would suspect that also. The only reman. pump I would go with is an AC Delco. Mine is working great, replaced it along with an AC Delco high pressure line.
GM bleeding procedure:
Old Feb 27, 2017 | 12:02 PM
leadfoot4's Avatar
OP, what are you using for p/s fluid? I had a '96 Z/28 for MANY years, and changed the fluid every couple of years, just as maintenance. One time, I thought I'd get fancy, and use synthetic fluid, rather that the conventional "red stuff". The car did NOT like the syn fluid, and the pump got somewhat noisy.
I switched back to the red fluid almost immediately, and fortunately A) the noise went away; and B) there was no permanent damage.
By Brett Foote | 2026-06-04 05:00:17
