Elite Engineering catch can on LT1
Or weld a bracket to the valve cover...I have a spare set of VC's.
Thanks for any tips.
https://ls1tech.com/forums/lt1-lt4-m...an-needed.html
If so, that is the general area I am talking about, but that doesn't show where/how you mounted it. It looks like you used the ICM studs?
Maybe I'll buy just the bracket then modify accordingly.
Went on easy as cake.
Camar0corey...I had the husky setup, but I was emptying it too often and this one is a nicely machined piece with sealing o-ring etc. Great craftsmanship and they work.
Strictly from an engineering standpoint, a catch can is not rocket science...but I can tell you the EE can will work better than the Husky setup.
For MY car DD 5 miles to and from work 5 days a week...95 miles later. This is a side effect of the car not getting to operating temp every time going to work:
Since that picture I added some steel wool inside to help condense the vapors. Did it work? Sure. Will the EE can work better..meaning condense more vapors into oil given the same volume of vapor passed through it? I'd bet so.
