LT1 Catch Can Needed??
Old Jul 23, 2012 | 07:56 PM
unioncarpenter84's Avatar
Default LT1 Catch Can Needed??
What determines if u need a catch can and who got pics of a catch can mounted up
Old Jul 23, 2012 | 08:24 PM
lt1slowz28's Avatar
if you are getting a lot of oil in the intake a catch can may be able to stop a little bit.
90% of people that have them on their cars don't need them, and usually it isn't even functional anyways.
Old Jul 23, 2012 | 08:27 PM
boostedskyline's Avatar
i've only seen them on turboed/supercharged cars to catch all the blow-by oil vapor so it doesnt collect in a pool somewhere in your pipes
Old Jul 23, 2012 | 09:05 PM
wrd1972's Avatar
Could not disagree more.
The PCV is required by guvment to reduce emissions period. The system does help do this but the negative impact is that there will be some oil that ends up making it into the intake and ultimately into the combustion chamber even with a bone stock motor but much more so with aftermarket cams.
The aftermarket catch cans do a very good job of ensuring that the PCV system works as intended without having oil make it into the motor. The only reason manufacturers dont put catch cans on their new cars is because most owners wont empty the can.
Ok all that said, here is my Norris Motorsports catch can for the LS1 and yes it fits any motor. It does a very good job of keeping oil out of my motor. Prior to using it, I had tons of oil in the intake that would drop into the motor to the point that from time to time, you could smell oil burning out the exhaust.
Looks factory and has about 1/2" of oil in it after maybe 1500 miles.
To conclude, their are benefits to keeping oil out of the motor by using a catch can on any motor including a bone stock one IMO. Just about anyone with an agressive aftermarket cam should really have the can if they have any signs of oil in the intake.
Old Jul 23, 2012 | 11:37 PM
lt1slowz28's Avatar
most people, the OP included don't know a soda can from a real oil catch can.
http://www.mikenorrismotorsports.com...atch_Cans.html
Old Jul 24, 2012 | 07:11 AM
DAVE00's Avatar
I have the same one as wrd1972 and works like a champ:
IMG_0611.jpg?t=1303422694
IMG_0613.jpg?t=1303422664
IMG_0612.jpg?t=1303422651
Old Jul 24, 2012 | 07:45 AM
quik95lt1's Avatar
this is extremely wrong lol........the pcv is there to pull combustion vapors out of the crank case.......remove your pcv and see how it runs.......99% of the "catch can" setups out there are plumbed wrong........then everybody wonders why their newly cammed car blows brown smoke when they are on the throttle......they wind up ring fluttering from all the bottom end pressure....a ventilation system is needed
Old Jul 24, 2012 | 07:53 AM
Tbird232ci's Avatar
How are your catch cans routed?
Old Jul 24, 2012 | 08:01 AM
quik95lt1's Avatar
i run a vacuum pump now but if not run your pcv hose to the top of a sealed catch can and run your valve cover lines into the side the can gets a vacuum pulled in it the vapors get pulled out top and back into intake and the oil falls to the bottom.......with a cammed car bigger hose -8 or -10an helps to move extra volume to make up for the lack of vacuum......
Old Jul 24, 2012 | 09:01 AM
Rob94hawk's Avatar
how do you know if you need one?
Old Jul 24, 2012 | 09:04 AM
DAVE00's Avatar
When I pulled my intake it was coated in OIL and to keep this at bay I decided to istall one. So far my intake has been staying pretty clean and the PCV has been clean as well as the catch can is doing it's job and getting it before it gets thru the PCV.
Old Jul 24, 2012 | 09:24 AM
wrd1972's Avatar
Okay I will respectfully respond.
Following is copied and just reinforces my belief but in much greater deatail. When they speak to it being added for California cars in the 60's, I think it is safe to assume the government mandated it. Highlights bolded.
"The Positive Crankcase Ventilation (PCV) system reduces blowby emissions from the engine. About 20% of the total hydrocarbon (HC) emissions produced by a vehicle are blowby emissions from gases that get past the piston rings and enter the crankcase. The higher the mileage on the engine and the greater the wear on the piston rings and cylinders, the greater the blowby into the crankcase.
Before PCV was invented, blowby vapors were simply vented to the atmosphere through a "road draft tube" that ran from a vent hole in a valve cover or valley cover down toward the ground. In 1961, the first PCV systems appeared on California cars. The PCV system used intake vacuum to siphon blowby vapors back into the intake manifold. This allowed the HC to be re-burned and eliminated blowby vapors as a source of pollution.The system proved to be so effective that "open" PCV systems were added to most cars nationwide in 1963. An open PCV system draws air in through a mesh filter inside the oil filler cap or a breather on a valve cover. The flow of fresh air through the crankcase helped pull moisture out of the oil to extended oil life and reduce sludge. The only drawback to these early open PCV systems was that blowby vapors could still backup at high engine speed and loads, and escape into the atmosphere through the oil filler cap or valve cover breather.
In 1968, "closed" PCV systems were added to most cars. The breather inlet was relocated inside the air cleaner housing so if pressure backed up it would overflow into the air cleaner and be sucked down the carburetor. No vapors would escape into the atmosphere."
Old Jul 24, 2012 | 10:35 AM
quik95lt1's Avatar
uncle sam says that LOL but in reality the vacuum it pulls through the crankcase is the real advantage in a performance situation......
Old Jul 24, 2012 | 01:43 PM
Rodinator1234's Avatar
I agree completely about the need for a catch can. They are inexpensive and easy to install and a good baffled catch can will superise you on the amount of oil it will "catch". The oil introduced into the intake tract causes a reduction in the octaine of the air/fuel charge. Even a little oil could cause the knock sensor to detect knock and pull timing. Every time I check my catch can there is oil in it. I check it every 1k miles or so. And yes in the old days, they just vented the engine there were no such means of pulling a vacuum on the crankcase. You guys have seen cars with hoses from the top of the valve covers run down to the top of te headers right? That's the same principle as running a vac pump. The Venturi effect of the speed of the exhaust gas will pull a vacuum on the crankcase. I don't disagree with the fact having negative vacuum in the crankcase is a plus. But PVC systems are here today because of the EPA/government.
Old Jul 24, 2012 | 03:20 PM
96lt1m6's Avatar
I think all cars benefit from this unit, FI or NA
Old Jul 24, 2012 | 05:27 PM
very good info on the catch can buy got one question.........when u install the catch can is there a special way tht it gotta be installed like the air flow going thur the can are there arrows or dont it matter
Old Jul 25, 2012 | 08:00 AM
It doesn't matter a baffled catch can or seperator causes the air to change direction several times which causes the oil to fall out of the air stream and collect in the bottom of the catch can.
Old Jul 25, 2012 | 04:23 PM
speed_demon24's Avatar
I'm curious to hear how 99% of the catch can setups are plumbed wrong. The 1/2" hose from the vc to tb is what vents the crankcase pressure, but I ditched that for a breather in each vc.
And all the newer hemis have is a 3/4" hose to the intake tube, no pcv valve or vacuum on the crankcase at all.
And if I could do it over again I would just run a breather tank from each vc and cap the pcv off.
Old Jul 25, 2012 | 08:00 PM
FormulaJoe's Avatar
I have the same one as DVS and after only 150 miles I can see oil starting to collect inside. Worth it.
Old Jul 25, 2012 | 09:11 PM
Rob94hawk's Avatar
Using this google image how would you route the catch can for a 1994 pcv setup?
