Nitrious On A Bolt-On LT1
Old Mar 3, 2017 | 04:57 PM
Birdracing's Avatar
Default Nitrious On A Bolt-On LT1
Got a wet Zex kit for a real steal could not pass it up installing on my 94 Z28, mods in sig, i am going to be spraying a 100 shot don't plan to go any higher. What is the best plug to use?, and do i need to get a tune for this? I already have a tune, i always read that a stock motor should handle a 100 shot is this right???
Old Mar 3, 2017 | 05:22 PM
stevo9389's Avatar
NGK was the plug of choice but I think at the time they were all using projected tips. There's threads buried in here about the topic of the most correct plug to use. A wet kit you could probably skate by without a tune but you had better have a wideband installed to monitor air fuel ratios. I have personally witnessed several stock LT1s (one with nearly 200k miles) take up to a 180 shot on regular occasions and the only failures came from user error or the transmission letting go. Others will have different experiences but these were mine.
Old Mar 3, 2017 | 05:31 PM
Birdracing's Avatar
I googled it and alot of old threads from here came up i got the plug i need with the correct gap and i should be good for tuning.. The car is no a every day driven car could go a week or more sitting, i was planning on doing a HCI, but this route is so much cheaper...
Old Mar 4, 2017 | 09:25 AM
TravisMcGill2000's Avatar
To be safe you need 255 fuel pump, a way to pull timing and run a ngk br6ef (3177). U would pull 4 degrees on 100 shot and 6 on 150. I ran same setup on a 200k mile motor. It ran great with no problems. Ran 11.2s
