radical lt1 head modification?
it might be an invalid idea, im not a cylinder head expert, but i wasnt sure if anyone else had thought of it. F1 lt1? lol
cookseyb: would you say the same for the intake ports? they are restrictive as well but a little less restrictive than the exhaust ports. how would having a restriction create a pressure drop. buildup of air would only create a pressure increase right?? nothing about that makes sense. the exhaust should come straight out for maximum flow! heat and small port/runner volume creates velocity but i dont want to make the volume bigger. if i could do this experiment on some heads, maybe i would just port the exhaust as normally done (or.. relocation between the rocker studs and close to the springs, maybe even carve out some material around the valve guides) and then do a relocation experiment on the intake to straighten the short turn.
update. i know this idea is getting crazier, but.... the damn valve guides are right in the way. thats why the ports are the way they are, so the springs and valves can get in their and do their job. but to get rid of this problem, why not elevate the whole valve/cam rocker system about 4-5 inches taller. an extension. it would probably require a whole new structure on top of the head to support and give rigidity to the rocker studs, pushrods, valves stems etc. i know im a lunatic but its all in theory anyway. now the exhaust has a much wider turn and flow numbers are only limited by the quality of the valve job and the intake.
thanks for reading.
