How to read IAC Counts
What you are experiencing during cranking is a cylinder starting the burn process in the earliest stage of the compression stroke. The result is massive resistance to the starter motor as the crank is being forced backwards.
I would start by double checking ignition cable routing at the cap. http://shbox.com/1/opti.jpg
