can i post a question about an engine swap here?
i have just installed a 1995 z28camaro lt1 and engine harness in a 1994 camaro z28 body. The 1995 motor ran before the swap. Currently i have no spark or injector and the fuel pump doesnt work for the 2 seconds or so when the key is turned on. Pump does work when powered at test port. My security light comes on the goes off after a few seconds with the key> Can anybody give me some help in this area? Thanks
Without knowing more details about your swap (trans involved?), you should be able to use the 94 engine harness (use the 94 PCM, too). You will need to use the 95 opti harness, though. The 95 engine harness won't work without modification.
