lt1 strange noise belt?
Hello,
I was wondering if there was a common pulley or problem to look for before i start taking it apart.
The car is a 97 has about 95k miles on it, it sat all winter under a car cover and after i started it i did not think too much about it, thought that when it warmed up it would go away but it never did,
It has oil and oil pressure and at first thought it sounded like a belt but now am wondering, i will take the belt off when i get home tonight but am wondering if there is anything common that goes wrong?
The belt is not even a year old/.
Any ideas thanks
Dave
https://www.youtube.com/watch?v=WWo6...ature=youtu.be
Any ideas thanks
Dave
Village Troll
I don't like those intermittent screeches not one bit. Take the belt off and see. If it doesn't disappear then worst case scenario cam lobes and roller lifters are bad. Check your oil for glitter.
Before you pull the belt off run the engine and carefully look at the various pulleys to see if any of them wobble. This can cause a 'funny' sound while the engine is running.
If it all looks perfect, check the p/s fluid, it may be low, causing a 'funny' sound. my .02
stan
stan
