Overheating at idle after warmup
Back again and was just going to get some suggestions on the overheating at idle issue i'm having as well. I've installed a new 180 degree thermostat and add coolant and watch it regularly. it seems to drop after i run it for awhile but have no issues of water in oil or oil in coolant. Also when i'm out driving and the car gets warm or I stop for about 3-5 mins and let it idle, that's when it over heats or wants to start rising in temperature. When i go back out and drive, it drops back down to 180 or below?? Wondering if maybe it's the water pump? It gets up to about 230-240 at times (rarely) and i don't hear the fans kick on either. Seems like it gets warm pretty quick too. Like i said, check coolant regularly as well.
is the air deflector still im place? its the flat plastic piece under the radiator. also bleed the air out, again and again and again. best way is to get the front of the car up when bleeding air out, steep driveway works great. helps to get that air to let loose from the back of the engine.
Figured out the problem guys. It was as simple as the blown 10 amp fan fuse. Fans turn on now and car stays at the temp it's supposed to. Thanks for all the responses! just me being an idiot and not paying attention to the fuse.
