94 firebird suspensión
I Just want to make sure everything under the car and suspensión área are good before going full thottle to engine mods. Please make a list of everything i need to change (front and rear) doesnt matter if is good or bad i will change them with New parts
94 Trans am, auto
Thanks
https://ls1tech.com/forums/suspensio...e-upgrade.html
Work on it is moving a little slow at the moment as some work and maintenance on the house and my four other cars is taking a little bit of a higher spot on the priority list right now, but I'm hoping to get some more work done on the lower arms this weekend and I'm shooting to have the entire build done by June 24th.
I'm hoping they're going to be like the front uppers I did where you just need to put in a spacer and use the correct press and receiver on a ball joint press. Of course, condition and rust make a big difference. The front arms I got are from Texas and with the exception of some surface rust from scrapes here and there, they're almost brand new. I'm curious to see what my arms are going to look like when I pull them off as my car is clean but still a northeast car.
http://www.ws6project.com/user_stor/catalog/82-02-umi-tubular-lower-control-arms-2/
Just another option for yah.
Just my .02
I'm also using an adjustable panhard bar with double rod-ends which will keep the rear pretty well centered and I'd be worried that as the rear moves up and down and the panhard moves the rear from side to side that the poly bushings would have an issue letting the arms articulate in that side to side motion that is needed.
