Anyone ever see this? Proform 1.6 rockers
Valve lash incorrect or the polylock came loose. Self aligning will do this at high RPM if valve train is not stable. Rocker is a bit loose, moves around at RPM and hits the end of the valve or the spring and bends the guide. Once that happens the guide cannot spin correctly and will not hold the rocker when the engine is running.
Only way to fix it is replace the bad rocker. Check the other rockers to see if any others have been bent/hit and replace. Change the oil because you might have aluminum shavings in it. Set the lash. Run the engine for a bit - whatever time you are good with - and replace oil once more. Just use cheap conventional for the short run time. Also change the filter at the same time.
The oil change might be a bit conservative but when this happened to me I noticed a shaving or two on the top of the head. Didnt want to chance it.
Better solution might be to go NSA. That is the route I took.
The following users liked this post:
2JAWZ (12-31-2020)
OP
are the SA washer tabs of the RR hitting the spring retainers??
pull RR and see if there are witness marks on the retainers
if so...go NSA RR and guide plates.
Comp Pro Mag (Ultra) and ISKY guide plates would be my vote. Get .080 thick wall hardened PR
Can't see it from the picture, but does he have enough valve tip for SA rockers? Could be the rocker tip SA guides are pushing on the locks and not the valve tip.
I'd say go 7/16" stud NSA, with hardened pushrods and guideplates. That's the same route I took.
10 degree locks & retainers give a little more "valve tip height" which helps SA RR clear......although I agree NSA & guide plates is the way to go. when running aftermarket springs & SA RR it is not uncommon to have clearance issues.
My $.02 if spinning motor to 6k rpm or more....go NSA RR & guide plates
