cc503 tune
Old May 24, 2017 | 04:38 PM
Jaxem's Avatar
Default cc503 tune
Went to get my emissions tested today, the car has run pig rich since doing cam and exhaust, i just didn't know how rich. It failed miserably at 10x the limit for hydrocarbons. I'm not sure if it's my tune or a leak somewhere.
Does someone have a tune for their 503 that i could look over to see how much mine differs? I'd rather not spend the $300 working on it to get the waiver when i'm guessing it's a wonky tune.
Background: The tune was done by Solomon, but has always been a bit rich, getting worse and worse over time. i went back and forth with him for a while, but he was convinced i had a leak somewhere, which multiple shops told me i didn't.
Someone help a brother out!
Old May 25, 2017 | 11:03 AM
BALLSS's Avatar
your tune could be off for the engine mods you have
you could have a exhaust leak pre-02 causing PCM to dump fuel
you could have a leaking injector dumping fuel
all the above will eventually kill 02 & CAT
Old May 25, 2017 | 07:58 PM
Jaxem's Avatar
This is why i'm hoping for help looking into the tune, i've had the injectors cleaned and flow tested, and had the exhaust checked twice...
Old May 25, 2017 | 08:19 PM
joelster's Avatar
What plugs are you running? What gas are you using?
Old May 25, 2017 | 10:04 PM
Jaxem's Avatar
just the regular TK55's on 91 octane e10 (best we can get here)
