T56 speed bleeder
Old May 31, 2017 | 06:46 AM
redz6speed's Avatar
Default T56 speed bleeder
Hi does anyone know if they made a speed bleeder for the lt1 style t56 like the Ls style? Buddy of mine has one for his Ls car made bleeding his new clutch easy. I'm in need of a new clutch master cylinder and wondering if they made one with a bleeder or if they made one on the steel braided line? Thanks guys
Old May 31, 2017 | 09:59 AM
smitty2919's Avatar
Nope.
Need to custom make one. Technically LT1 clutch hydraulics are not serviceable. But you could gravity bleed it.
Old May 31, 2017 | 12:41 PM
Spartan7's Avatar
Originally Posted by smitty2919
Technically LT1 clutch hydraulics are not serviceable..
In what way? You can replace individual components and bleed the system yourself, sounds serviceable to me.
OP, LT1 hydraulics do not need a speed bleeder. They are much easier to bleed than the POS LS1-style stuff. Search for the GM bleed procedure on here, it's been covered many times.
Old May 31, 2017 | 01:40 PM
smitty2919's Avatar
LS1 stuff is not POS with a speed bleeder
I suppose I meant to word it as the LT1 was not intended to be bled hence the lack of bleeder port?
Either way I plan to make a custom setup and not mess with pushing out the roll pin to remove the line and let it gravity bleed.
Old May 31, 2017 | 03:46 PM
Spartan7's Avatar
The GM manual has a bleeding procedure in it, you don't need a bleeder port. And I have dealt with LS1 hydraulics, and my personal opinion is it's a POS and inferior to the LT1 stuff. YMMV.
Old May 31, 2017 | 04:43 PM
SS RRR's Avatar
Village Troll
They are easy to bench bleed. Since you need a new M/C just take the slave and reservoir off and do it off the car.
