PCM Problems After Fix
Old May 31, 2017 | 01:31 PM
CamOnlyJabroni's Avatar
Default PCM Problems After Fix
After the JET DST software bricked my pcm from not installing correctly, I sent it to JET and they repaired it for free. I went to flash the pcm after installing the software correctly and it won't connect to the pcm. I also noticed there are no lights on in the cluster or car. Only thing lit up blinking erratically is the security light. JET said they may have flashed the wrong year stock tune for my car. Anyone have any other ideas. JET is sending me a stock tune but that doesn't help me not being able to communicate with the pcm. Any ideas?
Old May 31, 2017 | 02:48 PM
Purple Poncho's Avatar
When I hear security light I think VATS.
Old May 31, 2017 | 03:51 PM
That's what I am talking about.
Old May 31, 2017 | 04:42 PM
CFLFORMULA93's Avatar
mine did the same thing after recieving a mail order tune. my car is a little different bc of it being a 93 with the chip/eprom bs . long story short i had bent one of the pins on the chip/eprom during install/removal. the connection/solder actually was compromised and the car wouldnt start no power except security light flashing, tracked down a replacement and cured the communication issue. if you havent bypassed the vats already or tuned it out that could be causing an issue as well.
i would be checking all your connections .....
