Lt1 banjo bolt help
https://www.walmart.com/ip/Hanson-39...Piece/16494336
IDK if something like penetrating oil will help
You need to replace the washer gaskets on re-install if the old ones are toast when you do get the bolt out. Two per side sandwiching the steam pipe
@96lt1m6 I would love to but dosnt looks like they make kits for LT1 (that i was able to find) and all suggestions for do it yourself is to tap the hole. Dont want to mess with tapping it unless the engines out the car.
@****** Will do sir. Ty
I came across this a week ago. Ima try a junk yard this weekend but this will be my fall back plan.
Sorry bud, watch this video
http://www.zip-corvette.com/95-96-lt...GWcBoCDMDw_wcB
I bought one after testing the tensile strength of my last one when taking the engine out the bottom a few years ago. Did not like the seals that came with it so got different ones.
BUT you will be paying like $10-20 per fitting I would guess. I used AN swivel fittings when adding a PS cooler to the front of my car. Dem little buggers add up
https://youtu.be/MI4lFPyuiBs
I couldnt get the drive side bolt off at all. Even with a bolt extractor socket and a pipe wrench on it it's just a no go with it in the car. I could just pull the head but I'm thinking I'm goin to leave it. Only the passager side was clogged and that's been cleaned. When I back feed water into the pipe I can see water come out the driver side block and none from the passager so that's what got me to mess with the bolts in the first place.
http://www.ls1lt1.com/forum/showthread.php?t=92914
This is one of a few I found with alot of good info.
And here's one more with parts list on converting it.
https://ls1tech.com/forums/lt1-lt4-modifications/1312286-coolant-crossover-conversion-part-list-pictures.html
