Mono throttle body intake step in
Old Jun 18, 2017 | 01:15 AM
96famaro's Avatar
From: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
Default Mono throttle body intake step in
So just got everything back together and running. So what I was wondering should I block off the intake hole completely or block it off and leave a small drilled hole? I noticed that my vents when I turn the a/c on don't work like they should and I know it's because of that hole not being regulated by the iac. Car is doing good idling just not building vacuum for my a/c. What has everyone else done?
Old Jun 18, 2017 | 10:49 AM
SS RRR's Avatar
Village Troll
Do you have vacuum off any ports off your manifold? I do not believe your iac has anything to do with regulating vacuum to your hvac. The iac is only to control idle. I think it plumbs fresh air to the holes in each intake port. Did you install a more agressive cam with a wider lsa when you put things back together?
