lt1 sounds odd to me
Old Jun 23, 2017 | 11:37 PM
LT1Bird97's Avatar
Default lt1 sounds odd to me
Just put back together an lt1 finally with LE1 heads and his 224/230 cam, lunati lifters and rockers and comp cam pushrods. Had a machine shop adjust the rocker arms for me. Towed it over to a shop to have the exhaust hooked up and idk it still sounds really noisy to me so im not sure if I should drive it. I mentioned the noise to the exhaust shop owner but he said if my engine was really knocking I would know. I left the car for the night instead of driving it home. Oil pressure on the gage is at 50 on start up. I think I will pop off the valve covers tomorrow just to double check. Really hoping I am just paranoid, Ive heard these motors sounds like sewing machines but this is a pretty loud one.
Old Jun 24, 2017 | 01:32 AM
KW Baraka's Avatar
I don't hear anything wrong.......
KW
Old Jun 24, 2017 | 05:06 AM
atlantadan's Avatar
Sounds a-ok to me, but it is your car. Roller rockers will definitely make more noise than stockers, and some roller lifters can even tick a bit on cold start. Was this engine entirely rebuilt and you've not driven it yet? If so, certain aftermarket parts can make uncomfortable but harmless sounds. Forged pistons clatter on start, some Melling oil pumps can make a ****-ton of noise (I have one of them...its coming out soon...), and some lifters can really bleed-down when the engine is off.
Old Jun 24, 2017 | 09:32 AM
LT1Bird97's Avatar
ya I think I am just not used to the new parts. A lot more noticeable then how I remember the car stock but its been awhile.
I think im basically just hearing the engine cause mine sounds pretty much just like how this guys car sounds when hes at the front near the engine and then when you walk around to the back you can hear only the exhaust
Still a crazy noise for me considering the v8 engine in my 82 Elco is super quiet
One more question I have is I think I might have shorted out my digital odometer on the engine reinstall, either way the panel is completely dead for it.
Old Jun 25, 2017 | 06:38 PM
96lt1m6's Avatar
Your cammed Lt1 sounds normal to me as well. Sometimes the valvetrains are more noisy depending on the parts used.
Unfortunately, we cannot compare the sounds to an 82 simply because the 82 never came with 10.4:1 compression, roller cam, roller rockers etc.
Old Jun 26, 2017 | 10:51 AM
SS RRR's Avatar
Village Troll
If you installed a more aggressive cam your rockers are going to make more noise. It's hard to tell anything usually in a video, but I don't hear any distinct sounds to be worried about? Sounds like the tradition sewing machine whir a roller valvetrain makes.
