Iac position?
Old Jul 14, 2017 | 09:18 AM
94_LT1_TransAm's Avatar
Originally Posted by Ed Wright
Open the throttle blades.
Ok cool, I would also need to reset/realign the tps sensor along with it also right? Since I'm adjusting the throttle blade more open correct? Thanks for the reply
Old Jul 14, 2017 | 11:15 AM
BALLSS's Avatar
You can "slot" the holes of the TPS to rotate it back if opening the TB blades does throw the VDC of TPS out of spec
Old Jul 14, 2017 | 11:55 AM
awesome that's what I thought! Thanks guys. Now doing this, will it allow the car to have a better throttle response? Sorry for all the questions lol
Old Jul 14, 2017 | 04:38 PM
Ed Wright's Avatar
9-Second Club
No more cam than you have there, you likely won't need to do anything. As long as throttle angle shows zero, you don't have to touch anything else. Try 1/2 turn on the throttle stop screw first.
Old Jul 14, 2017 | 04:41 PM
Ed Wright's Avatar
9-Second Club
And, it won't improve throttle response. That is in the tuning.
Old Jul 15, 2017 | 07:24 AM
Viper's Avatar
This from a post I kept years ago:
You will often get better idle quality with an aftermarket cam by closing the throttle body stop screw as far as possible without the throttle blades sticking when closed. This takes better advantage of the idle air passageways in the TB/intake/heads, as well as the IAC valve. Once you adjust the screw, you will probably need to reset the TPS, so that it outputs between 0.55V-0.66V when closed, with the ignition on and engine off (slot the TPS screw holes to adjust it by turning). You would then need to use a scan-tool of some type to check the IAC counts at idle; they should be in the 20-30 range. If they are higher, open the TB blades further again, or drill out the idle air hole in the TB very slightly, until they get into that 20-30 range at idle. If they are much lower, close the TB blades even more if possible.
Old Jul 15, 2017 | 11:42 AM
Ed Wright's Avatar
9-Second Club
Not sure who wrote that, but drilling that hole out is not necessary for a small cam. Hard to undrill a hole if you go too far. It is needed for a big cam, not a small cam, like the LT4 "Hot" cam, etc.
Old Jul 15, 2017 | 10:40 PM
SS RRR's Avatar
Village Troll
What would you consider a big cam? I'm running the xfi 292 in a 396 and have the stock sized hole in the tb with no idle issues. Used the same tb with a solid roller only slighty more aggressive as well.
It's an honest question. Not trying to say my cam is large or anything of that sort.
Old Jul 16, 2017 | 02:02 PM
Ed Wright's Avatar
9-Second Club
Don't know the specs on that cam, but normally nothing under 250 @ .050".
Old Jul 22, 2017 | 10:48 AM
SS RRR's Avatar
Village Troll
The xfi cam is below that and my SR was right around the 250 range for intake/exhaust, so yeah, they were small cams in comparison.
Old Jul 26, 2017 | 07:15 PM
92camaroguy's Avatar
My car is exactly the same way since my CC503 install. My IAC has been at 32-34 at idle when I was stock. I have the stock throttle body on mine as well. My PCM was tuned by Solomon and now stays up around 100-120 at idle in park/neutral and around 130 in gear...
Mine and 2 friends who has almost the same set-up is the same. I don't know what he's doing to the tune or if it's the bigger cam.
On another note is the 30's suppose to be in closed loop? Mine starts off at around 100-115 then drops to around 30-33 but then will max out I thing I need to open the blades some more.
Old Jul 27, 2017 | 08:27 PM
  #32
I thought it may have something to do with the tune as well... Nice to see im not the only one lol. I was going to try opening my blades like Ed suggested, but I haven't got around to it yet
Old Jul 27, 2017 | 11:32 PM
  #33
kingtal0n's Avatar
I would open the TB wayyyyy before drilling any holes. its the same thing in the end, whether the air passes the tb blade or goes through a hole in it.
The way I set idle is, first turn off, or block the IACV passage of the engine. This way all the air going into the motor is coming from NON-iACV sources. Then, say I want the idle to be around 550rpm, I would set the idle manually to about 510rpm fully warm (using throttle body blade usually). Then, re-connect the IACV and let it take up the final 40-50rpm of idle speed. Open just a tiny bit when the engine is warmest.
Old Jul 29, 2017 | 09:16 PM
  #34
Ed Wright's Avatar
9-Second Club
Whoever wrote that piece about closing the throttle blades completely has no idea what they are talking about.
Only way a bigger cam LT1 would idle well that way is if the hole between the throttle bores (stock casting was enlarged. The IAC simply can not pass enough air alone for a larger cam, larger engine. You have to open the throttle blades, or drill holes the the throttle blades, like is often done to carburetors with larger cams. Down side is you can not undrill holes if opened too far. I have observed very small differences in variations in cylinder balance done wither way. DIY guys can more easily just crack the throttle blades open a little more.
Old Jul 30, 2017 | 06:52 AM
  #35
How far should you have to open them? I read the same thing and it said to open them 1/4 -1/2 turn. I tried that and still haven't gotten the idle set right.
Old Jul 30, 2017 | 11:45 AM
  #36
SS RRR's Avatar
Village Troll
You also have to take your TPS position into consideration when opening up the blades. I have my blades open just enough to see daylight and I have no issue. What is your idle set at tune wise?
Old Jul 30, 2017 | 04:11 PM
  #37
Yeah the TPS volts are in range .70 and at WOT it's 4.75 I thought 4.5 was max? My idle is at 850 but hardly sees it.
Old Jul 31, 2017 | 09:00 AM
  #38
Ed Wright's Avatar
9-Second Club
I don't know what you have, so this is a general answer. I don't know what you have for a scan tool. If your scan tool shows Percent Throttle Angle, you can open it more as long as it shows Zero TPS. Some computers allow higher TPS voltage than others. Some closer to one volt than others. As long as it shows zero percent throttle angle, the ECM/PCM does not care. I don't know where that .55 to .66 volts came from.
Out of somebody's butt, I'm guessing. It is not in any of my original GM shop manuals. Some cheaper scan tools don't show all the available parameters, so may give TPS volts, and not percent TPS. Open it to one percent, it won't want to idle back down. Bigger the cam, more tweaking needed to make it idle well.
LT1& LT4 manifolds have an idle air passage from that hole you see between the throttle bores, that opens into each intake runner. Really big cam (needing to idle like 900 + RPM) opening that hole some works very well for a stable idle.
And, simply setting the idle speed up in the "tune" is not all there is to that part of it either.
Old Jul 31, 2017 | 08:56 PM
  #39
Ed I am using EHack But I will try the one percent and go from there
Old Jul 31, 2017 | 09:31 PM
  #40
Ed Wright's Avatar
9-Second Club
i don't think you understand. At one percent TPS, the ECM will not let it idle back down. You MUST keep the percent TPS at zero. I have no idea what data ehack does or does not show.
