Iac position?
Old Jul 9, 2017 | 11:30 AM
elis94camaro's Avatar
Default Iac position?
I recently installed a cc503 cam and got a mail order tune for it. Using eehack I saw that at warm idle my iac position is at around 60. Is that acceptable? I'm having issues with it shutting off when putting it in reverse or drive so I'm wondering if this could be the cause?
Old Jul 9, 2017 | 12:42 PM
BALLSS's Avatar
IAC wants to be 30-35 (32) at idle. maybe yours are pegging at 160 when you add load to engine (putting it in gear, turning the wheel, etc)
what are they when you put it in gear and it stalls?
if 60 that should not be a issue.
do you have a tune for the new cam?
Old Jul 9, 2017 | 12:46 PM
It doe have a tune and let me check what they were when it stalled
Old Jul 9, 2017 | 01:18 PM
I couldn't get my log to open but i do remember it being a consistent 60
Old Jul 9, 2017 | 01:33 PM
Badazz 97 TA's Avatar
Eehack shows IAC position?
Old Jul 9, 2017 | 01:40 PM
I'm assuming thats what it was, but I could be wrong what else could it be showing?
Old Jul 9, 2017 | 03:29 PM
BALLSS's Avatar
If IAC is at 60 when the car shuts off...the IAC is not the problem
Old Jul 9, 2017 | 03:42 PM
Could that mean that my tune is off?
Old Jul 9, 2017 | 03:47 PM
BALLSS's Avatar
what rpm does the motor idle in neutral....then when you put it in gear?
Old Jul 9, 2017 | 04:18 PM
It idles at around 800-850 rpm when in park and then when I put it in drive it kind of bogs down and shuts off, I can keep it alive by quickly shifting into drive and giving it a little gas though.
Old Jul 9, 2017 | 06:32 PM
BALLSS's Avatar
stock TB?
Old Jul 9, 2017 | 08:24 PM
Yes it is a stock throttle body.
Old Jul 9, 2017 | 10:46 PM
LT1FirebirdSLP's Avatar
Mail order tune... from whom? Might be an indicator.
Something is happening where you either aren't getting enough fuel or air when the additional load of being in gear is applied. IIRC there is a table in the PCM that specifically applies to the A4 guys where additional idle air or fuel is added when placed into gear.
Yes. In datalogging and you can graph it too.
Old Jul 9, 2017 | 11:06 PM
I forgot to mention that it shuts down on me when it enters closed loop. When it is in open loop it goes into gear better but not 100 percent but it does not turn off on me.
Old Jul 9, 2017 | 11:14 PM
BALLSS's Avatar
???, higher than normal IAC counts (60) are common with aftermarket TB and cams, not so much with stock TB as they have the center idle air hole in them
Still IAC at 60 with engine at operating temp and no AC on is high. Should be 30-35. If you could read IAC counts when you put it in gear to see if they peg at 160. Then the car would stall
Who did the mail order tune?
Have you discussed your issue with them?
Old Jul 9, 2017 | 11:20 PM
I am still awaiting a response since I barely let the tuner know yesterday. I just wanted to get informed of what the problem could be before I heard back.
Old Jul 13, 2017 | 02:40 PM
94_LT1_TransAm's Avatar
My car is exactly the same way since my CC503 install. My IAC has been at 32-34 at idle when I was stock. I have the stock throttle body on mine as well. My PCM was tuned by Solomon and now stays up around 100-120 at idle in park/neutral and around 130 in gear... Is there a way to fix this or is it just in the tune?
Old Jul 13, 2017 | 03:24 PM
Ed Wright's Avatar
9-Second Club
Default Idle issues
That IAC number that high is your problem. I send instructions for fixing that with PCMs for vehicles with bigger than stock cams, back with the PCMs.
Old Jul 13, 2017 | 08:52 PM
Not trying to take this guys thread, but how do you fix this high iac issue Ed?
Old Jul 13, 2017 | 08:56 PM
Ed Wright's Avatar
9-Second Club
Open the throttle blades.
