A/C Performance
Old Jul 9, 2017 | 12:26 PM
sofixy89's Avatar
Default A/C Performance
Hello everyone. Was gonna pick your brain and see if you can help. I just moved down to TX and have low A/C performance witch I cant have down here First i dont feel like my blower motor is blowing hard enough. If i drive on the highway with max fan and a/c sometimes freezes. It just got a brand new evaporator so i know its not clogged and i just put in new blower motor and while replacing it i reached my hand inside to make sure no leaves and stuff was inside. Any way to make it blow harder? Maybe different squirrel cage that will fit it? I also get low to no A/C at idle, it will just start blowing warm air. Its 383 with decent cam in it and only runs 8psi vacuum on idle (11 or so highway). Is ac/heater core gate vacuum operated? how much does it need if it is? or my AC radiator needs cleaning? its a bit nasty. I know its a long post but thanks in advance for reading it. I just wanna be cool ��
Old Jul 9, 2017 | 02:08 PM
atlantadan's Avatar
Have you tested the pressure in the high and low side of the AC circuit? Also, if your condenser is clogged with junk, that'll definitely have an effect.
Old Jul 9, 2017 | 11:07 PM
LT1FirebirdSLP's Avatar
The lack of vacuum may be inhibiting proper operation of the warm/cold flap. Seems plausible given that you have better performance of the system on the highway when the engine sees higher revs than at idle.
Can you hear the compressor cycling?
Old Jul 10, 2017 | 02:44 PM
shbox's Avatar
The temperature control is not run by vacuum. It is has a cable. So, you can effectively rule that out.
OP, if you don't have the proper tools/skills to check out the system, I would have it professionally evaluated. Even the proper amount of charge will affect how the system operates.
Old Jul 10, 2017 | 03:00 PM
SoFla01SSLookinstok's Avatar
X2.
I always liked A/C repair. From what I read I would guess a low charge. Warm at idle & freezing up on the highway. Which opens up a new door. Where's the leak. Good luck.
Old Jul 11, 2017 | 06:27 PM
sofixy89's Avatar
thanks for all the input. I will have pressures checked. Also installed the new cage from 2001 alero to give it a bit more flow. ( had to trim it and all kinds of stuff to fit but was worth it)
Old Jul 11, 2017 | 08:41 PM
Cajun ELESS-ONE's Avatar
check to see if the coil is engaging on the compressor. mine will work intermittently. i put the scanner on it and it says coil is on meaning its sending voltage to it buy its not engaging. the clearance is probably too much. good luck on your findings
Old Jul 14, 2017 | 07:57 PM
smooveZ's Avatar
Had to have mine replaced. Spewing fluid everywhere!! $500.00 fix!
Old Jul 14, 2017 | 10:31 PM
thetransamkid's Avatar
Lolz, my A/C is the removal of my t-tops and rolling down my windows. Almost positive my AC system has a leak. I was able to jumpstart the compressor with some 12v wire, then I put the refigerant in it but it won't hold any pressure at all. Any suggestions?
