harnass
the part that has the fuse box on it, is it the same on every camaro/firebird? Can i use that part of a v6 on a LT1, of from a 96(lt1) on a 93(lt1)?
Car is a 94 firebird, but at the wiring harness (with the fusebox section) rats has eaten a lot of wires
http://shbox.com/1/harness_connector_faces.htm
http://shbox.com/1/harness.htm
i just has to look at the engine harness, and see if i can use a 94-97 Lt1 harness with his ECM on a 93 Lt1 engine
