LT1 Problems.. Fuel or Electrical issue?
FUEL PUMP issue......
Check for spark at the plug
IGNITION CONTROL MODULE
possibly an OPTI issue
I'd say start with the easy test pressure, if the pressure is good its not in your tank. If the pressure is bad check the plug. The plug is on the driver side of the chassis in front of the fuel tank. Pull it down and check for voltage and ground with a multimeter. If you have 12v at that plug, a ground and a signal wire then you have to go into the tank.
