is my starter going out?
Old Aug 12, 2017 | 11:00 AM
bobby678's Avatar
Default is my starter going out?
on a cold start it always take 2-3 turns to start and will sometimes make a sound of hollow metal smacking if i turn the key too soon after the other turns...
when its hot though it will start up first try.
Old Aug 12, 2017 | 02:38 PM
Heatmaker's Avatar
If it sounds like the starter solenoid it might be. It's easy to figure out if you put your car on ramps or jacks and have someone put the starter into the on position. You can actually hear it clacking. Most of the time though the starter just has loose wires or is greasy and isn't getting a good connection. IF all that checks out then the starter just may be heading down south.
