Steam pipe question
Old Aug 16, 2017 | 10:49 PM
nickp's Avatar
Default Steam pipe question
I deleted my heat and swapped to an aluminum radiator. The new radiator does not have a provision to hook the hose up from the Steam pipe. I would like to route the Steam pipe hose right into the water pump.
I removed all the factory "barbs" from the water pump, that the heater hoses hooked to. and then tapped them for pipe plugs. I was considering putting a pushlock style fitting in one of them and running the Steam tube hose to that. I know I will need to tap into a "hot side" of my water pump, which I'm not sure how to identify.
Do you guys see any problems with routing it like this? anybody done a similar set up and/or had any problems?
thanks.
Old Aug 17, 2017 | 08:16 AM
lt1-xjs's Avatar
You want it in the return hose going into the radiator.
Old Aug 17, 2017 | 09:53 AM
96lt1m6's Avatar
I would drill and tap the aluminum radiator then screw a nipple in for the steam port.
Old Aug 17, 2017 | 11:30 AM
lt1-xjs's Avatar
Just get one for the top hose. http://jagsthatrun.com/Pages/Parts_D...plice-Kit.html
