Ls7 lifter preload
Old Aug 28, 2017 | 07:50 PM
Dirty_Bird's Avatar
Default Ls7 lifter preload
What are you guys running for preload on here? Ive read 1/4 and then 1/2. Whats the consensus say?
Old Aug 28, 2017 | 08:37 PM
SS RRR's Avatar
Village Troll
Old Aug 28, 2017 | 09:40 PM
BALLSS's Avatar
^^^^^ this, 3/4
Old Sep 2, 2017 | 01:14 PM
Fast355's Avatar
Originally Posted by ******
^^^^^ this, 3/4
With 1.7 rockers and the 395' marine cam aka Ramjet/HT383 cam I found 1 full turn to be ideal. Less than 1 full turn had very noticeable lifter noise on startup.
Old Sep 2, 2017 | 01:44 PM
Fast355's Avatar
^^^^^ this, 3/4
Old Sep 2, 2017 | 01:51 PM
BALLSS's Avatar
factory lash is 1/2 to 1 1/2 turns...so somewhere in between is what most do
with that said I have only used factory original lifters or Comp 850's, not "LS7" lifters so don't know the plunger travel comparison between stock and LS7....but assume it is the same or very close.
Old Sep 2, 2017 | 05:22 PM
pantera_efi's Avatar
Default Lifter Pre-Load with AL BLOCK
HI ALL, MY "tech" is also 1+.
This FACT is due to AL block growth.
FIGHTING this problem was CORRECT YEARS AGO !
THINK, DO NOT FLOAT the Valve Train.
THAT "tech" was for NHRA S/S class. (1/4 turn)
Lance
Old Sep 2, 2017 | 11:43 PM
350 groundpounder's Avatar
I went with 3/4 past zero lash.
Old Sep 3, 2017 | 12:10 AM
Dirty_Bird's Avatar
Tried 3/4 turn, little loud. Gonna try 1 turn and see what it does
Old Sep 3, 2017 | 09:28 AM
Its a possibility that a lot of the clatter you are hearing is the roller rockers if you have them. Lifters should be quiet even at 1/4 to 1/2 turn unless something is wrong. I have the sewing machine sound rather at 3/4 turn or 1 turn. Aftermarket valvetrain usually isnt stock silent.
Old Sep 3, 2017 | 01:24 PM
BALLSS's Avatar
yeah you would think exploding wallet, highly machined, roller needle bearing rockers would be quieter than some stamped steel riding directly on a PR...but no
at 3/4 turn mine have the "sewing machine" sound
Old Sep 5, 2017 | 12:17 PM
Gangly's Avatar
I've always done 1/4 to 1/2 turn, but I like my valve trains a little "looser" than most.
