alternator disassembly
Old Sep 3, 2017 | 11:56 AM
Bengtson95's Avatar
Default alternator disassembly
im looking to take apart the alternator on my lt1, trying to polish the case. loosened the 4 visible bolts on the casing, its loose but wont pop off, anyone?
Old Sep 3, 2017 | 07:27 PM
Heatmaker's Avatar
I think there's a nut that locks in the spindle when you remove the pulley or something like that.
Old Sep 4, 2017 | 04:43 PM
Dirty_Bird's Avatar
Be carefull, if you pull up on it and stator comes with front case its a pita to get brushes and that back in. Should just undo the 4 bolts that hold cases together and undo the pulley nut, comes off fairly easy with an impact gun
Old Sep 5, 2017 | 06:04 AM
smitty2919's Avatar
