computer gremlins with stall
Old Jun 30, 2004 | 12:56 PM
AINT SKEERED's Avatar
Default computer gremlins with stall
A freind had a shifting problem in a 94 comaro after installing a 10 inch 3500-3800 stall and 3.73 gears. trying to fix the problem with a 96 obd2 computer but now it gets into wot mode the timing and fuel goes eradic.
Is there some kind of part that needs to be changed besides knock sensor?
WHo ever has had these problems, what did you do to fix it?
Old Jun 30, 2004 | 01:51 PM
steve40's Avatar
never heard of converting obdi to obdii, it goes the other way
besides the knock sensor, i think that obdii has a crank trigger sensor, not sure if there is anything else.
have you tried going to either pcmforless or madwolf for tunning. my car is obdi converted and took a couple of tries with pcmforless but we finally got the car to shift
Old Jun 30, 2004 | 04:09 PM
He did call pcm for less and for 50 he can send his file and they will fix it and send it back. Thanks, chad
Old Jun 30, 2004 | 05:01 PM
Vendetta's Avatar
An OBD-II computer will not work with a '92-'95 LT1... I've never seen it done before, though.
Old Jun 30, 2004 | 09:30 PM
DietCoke's Avatar
Actually, it's quite common to swap over and swap the harness to get around stall gremlins
Old Jul 1, 2004 | 09:41 AM
Gangly's Avatar
You can convert from OBD1 to OBDII with few/no complications if done properly.
