wipers easy question
Old Sep 19, 2017 | 02:33 PM
curacaoz28's Avatar
Default wipers easy question
i saw that there are 2 separate part numbers for the wipers (the arm and the black cover) but is there i difference between them?? does it matter if i install the one from left on right or vice versa?
Old Sep 20, 2017 | 06:21 AM
shbox's Avatar
With separate part numbers, I would assume there is a difference. Otherwise, they would be the same part number. So, it would matter which way you install them.
Old Sep 20, 2017 | 08:20 AM
Viper's Avatar
It does matter. I bought an aftermarket hood and and accidentally switched the wiper arms when reassembling. At first I thought something was wrong with the hood as the arm was hitting it (passenger side). Swapped arms, all good.
Old Sep 20, 2017 | 10:04 AM
SS RRR's Avatar
Village Troll
Could the arms be different lengths, because I believe the drivers wiper is longer than the passenger?
Old Sep 20, 2017 | 10:11 AM
Viper's Avatar
Front right is Length: 33.75". Front left is 33".
http://www.jegs.com/p/Dorman-Product...36509/10002/-1
Old Sep 21, 2017 | 12:46 AM
madhatter's Avatar
I ended up using the 98+ on mine, they look cleaner IMO. Also I know the 98+ covers can be swapped side to side even though they show different numbers, not sure on the 93-97 style.
