LT1 Hard to start
Old Sep 22, 2017 | 01:33 PM
Tedg's Avatar
Default LT1 Hard to start
My 1994 LT1 has become very hard to start. Must crank it 4 or 5 times. Then it sputters (seemingly on one cylinder) then it starts. Idles roughly, and at a higher RPM, 1500.
Runs O.K. when driving.
Old Sep 23, 2017 | 06:26 PM
96lt1m6's Avatar
May need
New cap and rotor-
New spark plugs
Fuel filter
Check fuel pressure.. pressure may be bleeding off
Old Sep 24, 2017 | 04:42 PM
95mysticta's Avatar
have you checked for stored codes?
Old Sep 26, 2017 | 02:55 PM
SS RRR's Avatar
Village Troll
Vacuum leak maybe? Does it do this once it's warmed up?
Old Sep 26, 2017 | 05:30 PM
nomoneyz's Avatar
Could be ignition related or fuel related. Check for codes, check fuel pressure, when was the last tune up done, and is your water pump leaking?
Old Sep 29, 2017 | 03:04 PM
LT1's Avatar
LT1
Might have bad check valve on the fuel pump which causes extend crank. Put fuel pressure gauge on it, and see if it holds pressure after priming up.
I had same problem ended up putting race tronix pump and hot wire kit. Now mine starts first try.
