LT1 header bolts part numbers?
Old Oct 17, 2017 | 03:34 PM
94TAisfast's Avatar
Default LT1 header bolts part numbers?
In my preparations for a head swap, I can't seem to find any 5/16 12 point header bolts. Does anybody know what the ARP part number on these might be?
Old Oct 17, 2017 | 04:44 PM
SS RRR's Avatar
Village Troll
Is there such a thing as a 12-point 5/16" made?
Old Oct 17, 2017 | 06:38 PM
94TAisfast's Avatar
I'm honestly not sure. https://ls1tech.com/forums/lt1-lt4-m...der-bolts.html The second and third responses mention what I think I am referring to. Logically, it makes perfect sense, same size bolt flange with a smaller head would make it far easier to get a wrench in there.
Old Oct 17, 2017 | 09:59 PM
banshe5's Avatar
Yes they do make 5/16" 12 point header bolts. I used polished stainless steel ones from ARP on one of my cars. I'd recommend just using a 5/16" 6 point instead though. I had to grind down the wrench so much to clear around the primary tubes that using an open end wrench on a 6 point would've been much easier.
Old Oct 17, 2017 | 10:43 PM
Spartan7's Avatar
Sure there is. I've had my ARP's for many years, and they clear my Kooks primaries. I also use one of these box wrenches, it gives more leverage and clears the headers easily.
https://www.summitracing.com/parts/a...1209/overview/
https://www.craftsman.com/products/c...-12-pt-box-end
Old Oct 17, 2017 | 10:48 PM
94TAisfast's Avatar
Just for my own curiosity, I could just use a plain-jane box-end, right?
And thank you for that link! I have been searching everywhere, but I've been filtering by engine and that one has no engine listed. That explains my trouble finding it haha
Old Oct 18, 2017 | 06:10 AM
banshe5's Avatar
Those are the same bolts I used and they are very nice. It's great that the Kooks have enough clearance around the primaries, that is something to keep in mind for the future. Unfortunately my Hooker longtubes did not have enough clearance without me grinding down the edges of the box wrench to get them on the bolts. Which I did with the bench grinder. Since then I've used the same ARP bolts but with a 6 point head on the multiple header jobs I've done since then.
Old Oct 18, 2017 | 10:31 AM
biketopia's Avatar
I was going to make the same comment about the hooker's I have on my car. There is nowhere enough room to get a 12pt on some if not most of the bolts. The 6pt worked but it was a combination of long & stubby wrenches to get the angles i need to work with, I'll be grinding and bending a wrench in the near future to have on hand to snug em up since the genI swap is almost done and running.
Old Oct 18, 2017 | 03:43 PM
Spartan7's Avatar
The nice thing about the tool I posted is that the head is slimmer than a standard 12pt box wrench, which is why it clears so well. A standard combo wrench barely worked, and it was too short to get any leverage. It was well worth the money for me.
Old Oct 18, 2017 | 10:50 PM
ACE1252's Avatar
I'm pretty sure the boxed in wrench in my picture below is the same one Spartan posted up.
I used the ARP 1" stainless steel header bolts with a 5/16 12pt head for this reason.....they are awesome header bolts. Zero trouble with any backing out in over 5 years.
